No Heat?
No Heat?
Hey everyone!
My bronco will warm up and maintain engine temp with no issues...hot, cold...whatever. But for some reason I'm not getting any heat in the cab when I turn it on...luke warm at best. Any ideas on what might be causing the issue? Cold weather is coming and it'd be great to have a 4x4 that wasn't freezing haha.
Your blower motor is working fine? If it is you should confirm that you have coolant flow through your heater core, it should get pretty hot. If it's not that you might have a problem with vacuum hoses for your controls. Make sure the vacuum motor(small canister thing with a vacuum line and rod coming out of it), against the firewall on the far passenger side corner (sitting on the plastic blower housing) doesn't have a cracked line; make sure the little arm sticking out is connected to the piece coming out of the housing.
Hey everyone!
displacement4me
01-18-2009 11:39 PM
cr9c1
01-01-2007 01:57 PM
Dylansdad
09-08-2004 01:34 PM
