2002 explorer 4.0 Non supercharged. no power unless you disconnect the dpfe sensor. Suspect clogged cats. Am I barking up the wrong tree? How do I verify its the cats?
Thanks
Reason: Follow up
Pull the OBD II codes. Clogged cats are not unheard of but not that common.
These engines have intake o-ring vacuum leaks, cracked intake vacuum leaks, fuel pump issues, timing chain issues, and other items that can cause a loss of power.
