04 Fummins F250 CC FX4 on 05 Frame
I traded off a the cab/bed/doors of my 69 CC project for an 04 CC swapped to an 05 Frame. Its the lariat package. It was a painful thing, but I didn't have the cash to finish the old 69 nor did I see it happening in the next 10 years. Here's the interior/frame I'm working with:
I got the 60# pac brake springs in and the 4K RPM GSK installed. Engine - 1997 12V (no- engine plate) it came from D3500 with Auto so I'm guessing it to be stock 180hp.
Mod's:
HE351CW turbo with boost elbow
3rd Gen Exhaust Manifold (to clear ac box on SD)
4K- GSK
#4 Fuel Plate all the way forward
Pacbrake- 60# Valve Springs
Timing advanced Stock-
Transmission - 47rh 4x4 Built for 600HP with upgraded valve body
Billet Torque converter (brand unknown- supposed to be triple
disc but I'm skeptical)
Transfer Case NP 273 with input shaft swapped out to 23 spline.
Leaving it electric shift for the time being
Controller- I build controllers to automatically control OD and LU
at set speed for the 47Rh. Been running those for 2 years now.
Accessories- using Dodge AC compressor and Alternator.
I'm looking forward to the build. I'm hoping to get close to 300 HP. I'm not head-studding so I'm not getting crazy with boost.
Well, i've made a lot of Progress. ITs all buttoned up on the drive train side of things. I got my tranny mounted and the drive shaft shortened about 1-1/2 to accommodate the longer 47RH. I swapped out the input shaft on the 273 transfer case to fit the output of the 47RH. It was pretty simple once i finally got the casing to divide. The OEM sealant is was the real deal
Not sure what happened on the order of the pics. I also got the 4" Straight exhaust (alumanized steel) all buttoned up. I used a portion of the 6.0 down pipe but had to cut a wedge to well in to seal it up. It was a challenge but, its all done now.
I relocated the Degas bottle because it would not fit with the stock intake horn in place.
I also built a batter tray out of 1/4 plate to move both batteries to Drivers side. I used the stock 6.0 CPS to get the tack working. All was going lovely until i got a new tensioner and belt and buttoned up the alternator. Suddenly i have no Tach. I had cranked it several times and made a loop in the driveway and it was working fine. I have repositioned the sensor in every configuration and swapped the sensor out. STILL NOT SIGNAL. tach doesn't even bounce. Also, my odometer does not light up. When i turn key on, everything goes through its test for startup. Fuel gauges works, but no speedo, tach or any other gauges are reading. I still have to get speed signal figured out for speedo. Any help on tach and odometer?
Lastly, the interior lights, blower motor for fan etc, are not coming on-- What's missing.
NOTE: I just noticed the picture has the Dodge alternator in place. I switched to the Ford Alternator, but i am used the Dodge AC compressor which is not plumbed in yet.
Ive got a Hybrid situation here. I have 04 Body with 05 Frame. I believe the 05 harness was all swapped over. The guy i traded with, actually used his lift to make the body swap. He put the 05 dash in the 04. I did have a question or two about connectors that i had no home for on the under dash fuse panel. I know there are usually some unused plugs but here's what i don't have a home for...
side view
There may be one other plug, but i don't have pics of it.
side view
Ayumifanshawn
02-22-2019 07:40 PM
