6.0 intercooler and trans cooler install on 95 f350
Hello, I'm currently installing a 6.0 intercooler and trans cooler on my OBS. I have my brackets figured out and have all my parts to install but I just can't figure out the sway bar. My truck is a 2wd so it has the humped bar which is right in the way. I initially thought about making a drop bracket to lower it. I think if I do that it will be so low that it will contact the the steering links. I have a 97 f250 to look at and it doesn't even have a sway bar. I would like to keep the sway bar if I can as this truck is my long distance hauler. Does anyone know if the f350 had a sway bar that could be mounted up? I don't mind Fab'ing to make it work. I tried to find some of the other guys who put in the 6.0 cooler to see what they did but I can't really tell from any of the pictures.
Thanks
Scott
Thanks
Scott
Thanks!
I was thinking about putting an angle on the drop brackets after seeing commercially available brackets for the SD.
I might just pull the bar down to the right angle, then make up brackets with an angle with 1/4 plate. Once I get the angle dialed in I'll box out the plates to make solid brackets.
It's good to know it will work before I put the time into building it
]I got everything kinda mocked up in place. I marked out the areas I will cut out with a plasma cutter. Once I move the condensor back I'll have to room to clear both coolers. My early 99 spider should be here tomorrow so I can start playing with pipe locations and routing. I plan to use SD 7.3 pipes. I will cut them to fit and re weld them accordingly.
I'm also in the middle of building a new E40d for this truck. I've been working with RacerX to get the parts I need to make it solid. That's how all this began. I wanted a 6.0 trans cooler so I figured I'd be better off doing the intercooler with it.
Now that Matthew has past I actually got out to work on the truck today. I mounted both coolers and they seem to fit nicely. Please don't make fun of my crappy MIG welding
I added a 1/4 spacer for the top mounts to give me enough meat to run a 3/8-16 tap. The next part will be the drop bracket for the sway bar. I need to run out and grab a piece of 2x2 thick wall to run between the two brackets. I hope this will help stiffen the front and I plan to place it so that it becomes the lower mount for the transcooler. After this I just need to pick up a spool gun and I can get my pipes complete
