460 hp?
460 hp?
Hey guys I built this 460 I'm trying to figure out what kind of power in making.
85 460
Stock block. Stock rods and crank
Forged Pistons 9-5-1
Comp 292 duration 5.18 lift 107 lob sep cam
Dual valve springs with dampeners on d3 heads. Not sure if they are ported.
Eddy performer rpm intake
750 vac sec
Recurved distributor with electric fuel pump.
Long tubes 1 7/8 and 2.5 duals
I was hoping 450 -500 range
85 460
750 vac sec
I think you might be shy of 450, if this is within 10-20%:
460 Horsepower Chart (revised 1/24/09) - 460 Ford Forum
on
that's a lot of cam.do you drive it on the street at all? will she even low idle lol?
edit; oh ok.thats gotta be advertised duration and that's not real big lift for a 460.nice and lumpy idle though.your post helped me find comp cams *****' Thumpr 34-601-5 that i'll go with for my 429.so thanx!
http://www.compcams.com/Company/CC/c...csid=1491&sb=0
you don't have good enough heads to reach your goals.
on
for most people i bet they will end up with a better power curve with a vac sec carb because they are not so fussy to tune like a double pumper is.those who don't tune the dp correctly will just bog and the one with a vac sec will go flying by.
then passed yet again when the bogger is refueling lol.
I see what you are talking about. That cam is a towing cam, good to 5600 rpm they say. Not a wild cam. DP carbs are supposedly for light vehicles with short gears or so I've read.
Others have been critical of the "cook book" presented there as well. I think it's like a lot of "lists" or "how-to" things: YMMV
85 460
750 vac sec
85 460
750 vac sec
william16339
07-11-2016 10:33 AM
gus11208
16
03-04-2016 11:35 AM
jamies460
15
12-27-2005 07:22 PM
83gt
01-29-2005 10:52 PM
shazam
25
11-19-2002 02:33 PM
