my truck has the ford 9", 3.00 gear, and looks like this\/ it has the internal seal and it's 31 spline is this normal?
Yup, you have the sealed ball bearing axle. On later trucks Ford also used the tapered bearing axle with an outside seal, the "set 20" bearing.
Bearings don't interchange between axles but complete axle assemblies can be swapped between rears, just remove the inner seal.
I actually like the ball bearing over the tapered. It doesn't depend on getting lube from the differential.
