1968 f100 Gauges Issues
I appreciate the reply Craiger, but I don't have them hooked up. When I hook them up, the gas gauge appears to work properly but temp and oil pressure do not. Also, the regulator gets hotter than donut grease!! According to Dennis Carpenter it's a grounding issues but I'll be damned if I can find it! I've added ground straps to the truck etc... If a sending unit were bad would that be considered a bad ground??
Is the wiring OK through the firewall and on the engine for those two gauges? I would hook everything back up except the temp gauge. Then check it out. Then hook it back up and disconnect the oil gauge. And check that out. See if it's one of the two gauges or circuits that is the problem.
johnmel59
10-31-2018 01:53 PM
1979camperspecial
07-22-2014 12:08 PM
