1997 f350 7.3 mystery problem
Old 09-22-2016, 11:54 AM
knottyrope's Avatar
knottyrope
knottyrope is online now
puffs of white means unburned fuel or coolant, does it smell like diesel or sweet like coolant?
you could have a glowplug bad but that wont happen on a warm day unless you have an injector that needs shimming from being worn out. It retards the ignition and only cure is to shim or get a faster starter. you can shim them your self though
Old 09-22-2016, 12:05 PM
Jcollins6695's Avatar
Jcollins6695
Jcollins6695 is offline
Definitely, with out a doubt, diesel haha. Runs rich at idle as well (idle is rough as stated in the original post).
Would an injector that needs shimmed still pass a CCT and Buzz?
Old 09-22-2016, 03:12 PM
lee00's Avatar
lee00
lee00 is offline
White is either unburned fuel (overfueling, glow plug, or loss of compression) or water (head gasket, injector cup, cavitation, cracked head )....
Old 09-23-2016, 12:50 PM
ZachH's Avatar
ZachH
ZachH is offline
Did you replace the CPS with an oem (Motorcraft or International)? I had almost the exact same problem and couldn't figure it out, I had already replaced the lift pump, cps, hpop, checked the icp etc... I was advised by Moose_Machine to swap to an oem cps and haven't had a problem since.
Old 09-23-2016, 07:06 PM
MoBill122's Avatar
MoBill122
MoBill122 is offline
Papa Smurf
Check anti freeze for diesel ?
Old 09-23-2016, 07:12 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
As far as I know, there is no such thing as "shimming" injectors.
Old 09-23-2016, 09:51 PM
79jasper's Avatar
79jasper
79jasper is offline
Armature clearance can be shimmed back into spec.
Old 09-23-2016, 10:02 PM
Jcollins6695
Nope, autoparts store "Grey".
Are they really that bad? It had a grey one when I bought it, it was replaced basically right off the bat (before reading about the CPSes on these trucks), I warrantied it out the other day just for what I felt to be good measure. If you insist I will swap a known good one in its place. The symptoms do fit a bad CPS, how ever I thought surely out of the 3 greys that have been installed, one of them would be good off the shelf.
And to clarify on the white smoke situation, yes its unburnt diesel. I should've clarified that I knew this. Truck passed compression test (all in the high 3s).
In my opinion, something is telling injectors to pulse after TDC (causing the white smoke, and detonation ping). Does this fit the armature plate symptoms?
All injectors passed their tests, all injectors have new Orings. All injectors are "firing" when I manually unplug them (engine on, valve covers off).
Old 09-24-2016, 09:30 AM
MoBill122's Avatar
MoBill122
Papa Smurf
In a new injector clearance between the armature plate and adapter housing of the
injector is 0.004” Poppet valve wear will reduce this clearance to zero over time. You can add a shim up to 0.002" to fix this issue, anything more, you need to get a new or rebuilt injector.
Old 09-24-2016, 10:09 AM
ZachH's Avatar
ZachH
ZachH is offline
It is unlikely that both of the offbrand CPS are defective. From what I read the issue is with the inferior internals of the sensor. They have been known to be bad off of the shelf, I would think that it would be highly unlikely though for you to have two in a row that were defective though. Swapping in a Motorcraft has so far seemed to have solved my issue though.
Old 09-24-2016, 11:47 AM
knottyrope's Avatar
knottyrope
That also retards timing when the poppet gets worn.
Old 09-24-2016, 01:42 PM
Jcollins6695
MAJOR UPDATE.
So i put some clear hose between the hardline coming from the tank and the inlet to the lift pump.
HOLY AIR BUBBLES! I had air, which I thought I had previous ruled out by running the truck on off a fuel jug with an independent line. I stopped at advanced auto, bought 16ft of 3/8 hose, ran it straight off the lift pump down the filler neck into the tank until it bottomed out. I have just shy of a full tank now so it shouldn't draw any air.
Drove the truck 4 miles home, the truck still have a roughish idle, still missed up top, but the idle was noticably quieter without a doubt.
How long does it take to work air out of the fuel side of the FI system? Should I keep driving it and to work the air out or?
  #28
Old 09-24-2016, 03:22 PM
79jasper's Avatar
79jasper
79jasper is offline
Having air at the tank, you'll never "work the air out."
  #29
Old 09-24-2016, 07:08 PM
madpogue's Avatar
madpogue
madpogue is offline
What does it do on the other tank? Have you checked the supply lines from the tanks to the selector valve?
  #30
Old 09-25-2016, 01:51 PM
Jcollins6695
I think you missed the part where I said I ran a brand new, independent hose straight off the lift pump and into the tank, where it is submerged constantly in fuel.
My question was- now that that is done, how long does it take to get rid of the bubbles that are further on in the fuel system from the original, leaking hose.
Quick Reply: 1997 f350 7.3 mystery problem
