88 ford truck
Have you checked for spark?
Does the frame pump run for one second when the key is turned to the run position?
What engine do you have?
You can not know if the fuel pressure is OK at the rail without a fuel pressure gauge.
Have you tried resetting the fuel cutoff switch?
Does the small black wire with a green stripe have a good ground at the NEG (-) post of the battery?
This is what happened i had never used the back tank since i had the truck and i had the truck running and then the truck cut off and i smelt something burning and it had melted the wires to the swith thats switches the tanks and then wouldn't start and i didnt hear the pump running so i just ran a neg and pos wire from the battery straight to the pump in the tank by passing everything else and i can hear the pump coming on now and it still won't start
It was running fine until some how my switch got flipped to the back tank and i guess it had a short or something to make it melt the wires like it did because i never used the back tank since i had the truck and i know its getting fire because i sprayed it one time with carb. cleaner and it fired right up and cut right off
FroggyAimee
17
07-06-2018 06:40 PM
bmonnig
01-11-2007 08:48 PM
shane733
04-05-2004 04:21 PM
