F-4 brake drums
Old 09-13-2016, 04:10 PM
Jafo56's Avatar
Jafo56
Jafo56 is offline
F-4 brake drums
Hey guys I am wondering is there any particular way to get those screws out of the back brake drums? And also do they come right off after?
Old 09-13-2016, 04:54 PM
dschr60's Avatar
dschr60
dschr60 is offline
Spray lots of PB blaster or your favorite rust busting spray. Hit them a few times a day for several days before you try and remove them. I used an impact driver with a large flat driver tip. Keep pressure on the tool to avoid destroying the slot. Last choice is drill them out.
Old 09-13-2016, 05:04 PM
raytasch's Avatar
raytasch
raytasch is offline
Believe Nothing
What he said above. A good hammer type impact wrench and a BFH.
Old 09-13-2016, 07:41 PM
Jafo56's Avatar
Jafo56
Jafo56 is offline
Got ya! Thanks, they were my thoughts as well just wanted to be sure.
Old 09-13-2016, 07:42 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
I used the impact driver on my F4 drums and they all came out fine. On an east coast or rust belt truck they may be rusted in more than mine were. A little heat on the bolts won't hurt either. Once you get them out, you will probably need to back off to adjustment on the brakes to be able to pull the drums off, as there may be a ridge on the inside edge of the drums.
Mark
Old 09-13-2016, 07:51 PM
df85732's Avatar
df85732
df85732 is offline
I was inpatient and actually drilled them out. I then found new replacement screws with a countersunk hex head. Just make sure you don't mess up the threads. Of course I used a lot of Blaster also!
Old 09-14-2016, 09:25 AM
Mixer man's Avatar
Mixer man
Mixer man is offline
I was expecting the worst case scenario so I soaked them liberally with penetrant, slightly ground down a drag link socket and used my air impact wrench. What a waste of time, they flew out.
Old 09-17-2016, 02:03 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Yes, I replaces my screws with new ones that has allen heads. They make them with torx head too which might be better. I used anti-seize compound when I put mine back in and was glad I did when I had to remove the drums a couple years later.
Old 09-18-2016, 06:42 PM
cstempert's Avatar
cstempert
cstempert is offline
Usually they come out but if not ...heat to red, let them cool, little spray lube and they'll come right out
Old 09-18-2016, 07:41 PM
Mixer man's Avatar
Mixer man
Really, they serve no practical purpose once the wheels are mounted and torqued. You can leave them out if you wish.
pgw85706
1983 - 2012 Ranger & B-Series
03-03-2007 09:11 AM
vjl99
1997 - 2003 F150
06-01-2006 04:14 PM
rhetor
01-04-2004 06:58 PM
XLT O_R Ranger
11-20-2003 09:41 PM
Quick Reply: F-4 brake drums
