1966 - 1977 Early Broncos
ball joint diameter? 74-77
Old 09-13-2016, 08:50 AM
0351mike's Avatar
0351mike
0351mike is offline
Any help would be greatly appreciated.
I have a 74 Bronco. it had drum front brakes. I converted it over to disc using a 76/77 front disc steering knuckle.
I had a shop install the ball joints and reassemble the front end. When I picked the truck up the mechanic said the ball joint diameter did not seem to be correct diameter. when placed into the axle, the nut would not draw down onto the knuckle- so they used a big washer to take up the slack. This was the beginning of my steering problems. The truck ever since had steering problems. I took it to another shop for realignment and they sat the front end is binding- to tight at the knuckle. So before I go pulling this back apart can anyone confirm their are different diameters in the ball joints. I think the original shop ordered joints for a 74 and they should have been for a 76/77 due to the steering knuckle or maybe the other way around- joints to fit the 76/77
Or am I just totally wrong?
Old 09-22-2016, 10:38 AM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is offline
Received 1,358 Likes on 1,073 Posts
According to Rock Auto it uses the same ball joint for both years.
EDIT: just noticed that you asked last week. Not much activity over here, is there.
Old 09-24-2016, 08:04 AM
chrlsful's Avatar
chrlsful
chrlsful is offline
ball joint problem
Yes, this is pretty much of a dead zone.
I don't have answ on this Q. I'm 70% off rd & as long as it don't hit a tree, logger, or draft animal all's OK.
I DO know the '76/7 has different ster. linkage geomitry than all other yrs (along w/the discs) but that's not ur issue.
Head over to classic broncos . com for more action/definitive answer…
But watch out, there's some egos over there. They can pin back yer ears.
For I6 or falcon six answers B sure to C fordsix dot com. Not many on that site (CB) have the definitive answer 2 those motors (all 6 models: the big6 or sm6, 2 of which were in da bronk - 170 & 200).
Let us know how U do!
leadman1
1999 to 2016 Super Duty
08-30-2017 06:48 PM
Talyn
04-08-2011 09:41 PM
mike1956
12-02-2006 11:35 AM
76f150_4x4_360fe
04-10-2006 10:10 AM
Narwhal
08-19-2004 11:57 PM
Quick Reply: ball joint diameter? 74-77
