2002 explorer no start ignition key
new guy here...2002 explorer- broken shift lever- replaced complete colum from another 2002, swaped key and switch from original colum . won't even crank now. ran fine before. checked wireing harness , has all the same color wires and number of pins...anyone been here before ????
Do you get the normal indications otherwise such as accessories working when the key is in the On position and the bulb test when the key is in the Run position? When in the Start position, does the instrument cluster go blank like you would expect? Do you have a multimeter so you can check for the appropriate voltages in the Start position? Have you checked all the fuses to make sure one didn't blow through the swap process?
-Rod
-Rod
Texasdeereandhorse
07-12-2019 08:02 AM
Brandon Brown112
06-11-2018 07:07 AM
Soulphire
11-20-2016 07:26 PM
1998Ranger25L153CID
05-04-2016 10:22 PM
kiteman
08-26-2014 11:00 PM
