Gears or cams for an under powered 4.6
I've posted here before that I am very unhappy with the power of my truck. I've had it in the shop and they tell me everything is fine. I realize this is a 5500 lb vehicle with oversize mud tires and a small 280 ci V8. So with that said what would benefit me the most. A gear swap or a set of cams. They are about the same cost when all is said an done. The guys a MHS tell me I will have a noticeable gain in low and mid-range torque and power with their toruqer cams. What I'm really looking for is the truck just to drive better.
Only thing I have done to the truck is put on some 285's in place of the 265's. But it seams like a real dog to me. If I keep it out of OD and let it rev around 2400 rpm it does much better. But if I keep in in OD it's constantly down shifting to pull even the slightest grade. This is running around 60 mph.
on
When I put the 315s on mine, I basically lost 5th gear. I bought a superchip programmer, & it helped quite a bit, even though they claimed only a 9hp increase. A few months ago I notice an update on their website bumping it to 21hp, so I tried it. I can now cruse over the mountains in OD at 75.
Do you feel you need more gear with those big heavy tires? What octane fuel are you running? I was leaning towards SCT cause of the custom tunes you can buy.
