General Diesel Discussion
F250 7.3 deisel hit by lightening!
Old 09-12-2016, 02:25 PM
finn12's Avatar
finn12
finn12 is offline
Looking for some help. My truck was struck by lightening and will crank but will not start there is no wait to start light . Fuses are okay. my diagnostic meter will not read codes. It says no connection. I changed the pcm. No effect.i checked the heating element in the filter . it is okay.I have tried to find burnt wires nothing found. replaced solenoid for glow plugs. solenoid does not activate when you turn on key!I am getting the constant 12 volt but no ground to activate.1997 F250 7.3 diesel.
Old 09-12-2016, 04:35 PM
madpogue's Avatar
madpogue
madpogue is offline
Did you TEST (not just visually check) the fuses? Did you test for power at the #22 fuse socket?
Old 09-12-2016, 05:25 PM
finn12's Avatar
finn12
finn12 is offline
Yes #22 power in and out at the fuse
Old 09-12-2016, 05:36 PM
finn12's Avatar
finn12
finn12 is offline
With the key on. I pull #22 in and out and it clicks number two solenoid!
Old 09-12-2016, 10:35 PM
madpogue's Avatar
madpogue
madpogue is offline
Does the GP relay click when you do that?
Old 09-13-2016, 06:10 AM
finn12's Avatar
finn12
finn12 is offline
No it doesn,t click. All so i do not have a repair Manuel and i do not know if I have fuel pressure. I cranked it with the filter out and the bowl filled up slowly.I also do not see a check engine light when i turn the key. I know i am bouncing around. I just want to give you as much Info as I can. Battery's are both good! And thanks for your help.
Old 09-15-2016, 12:40 PM
retiredsparky's Avatar
retiredsparky
retiredsparky is offline
Without a good scanner, you are just guessing. There can be many wiring problems from lightning. The high voltage can jump from one wire to the next and actually blow wires into multiple short lengths. I would unbolt all grounds to check for clean metal. It is possible that much of the electrical system on the truck could need replacing. It might be smart to look for a wrecked truck same year, to salvage the wiring harnesses and electronic parts.
Old 09-16-2016, 04:20 PM
finn12's Avatar
finn12
finn12 is offline
Thanks for your help. i am hoping wiring harness is okay . i have been ohming it out. So far so good .replaced the IDM waiting on having my pcm rebuilt! thanks for your help!!!
Old 09-24-2016, 03:52 PM
finn12's Avatar
finn12
finn12 is offline
What is a good scanner to buy for my F250?
Old 09-28-2016, 03:31 PM
knottyrope's Avatar
knottyrope
knottyrope is offline
I use this
https://www.amazon.com/Vgate-Bluetoo...rds=vgate+OBD2
Torque Pro
https://play.google.com/store/apps/d...g.prowl.torque
Use the communication in the profile
SAE J1850-PWM
make sure you add in Ford PIDs
https://play.google.com/store/apps/d...ch.CarGaugePro
people like it cause it will pull codes but i have no bought it yet
Some OLD PCM's have to be flashed before you can pull codes
Old 09-28-2016, 07:37 PM
79jasper's Avatar
79jasper
79jasper is offline
I would replace every wire possible.
On another forum a guys truck was hit by lightning also. Replaced some stuff, still had issues. Then a couple months later it went up in flames next to the garage.
Old 10-18-2016, 11:42 AM
johndeerefarmer's Avatar
johndeerefarmer
johndeerefarmer is offline
I had a friend about 10 years ago that had a 7.3 hit by lightning. It fried his PCM
Old 12-03-2016, 11:25 AM
finn12's Avatar
finn12
finn12 is offline
Okay After replacing the pcm,idm , and multiple engine multiple sensors, transmission solenoid. I have one problem left . the od light is flashing and erratic shifting. i have a scan code of( 214 accelerator positioning sensor intermittent)I also changed the speed censer in the rear! i just change the accelerator positioning sensor same code. i am going to check the the three wires back from the sensor. If the voltage,ground and signal wire check out.Where do i go from there? thanks, Frank
Old 12-04-2016, 12:21 AM
retiredsparky
This makes me think that there are damaged conductors between the sensor and PCM. Lightning is very powerful and it's easy for it to char wire insulation which can cause either a partially broken conductor (crystallized copper), or a high resistance connection between two adjacent conductors.
A wire harness from a junkyard truck of the same model year would likely solve this problem. It is possible that the main connector for the PCM was damaged. The individual pin connectors sit in an insulating plastic block which may have been charred by the lightning.
Since you changed the PCM and the accelerator sensor and still have the code, it has to be in the wire harness or connectors. The digital meter you are using to test with does not produce the same voltage as the PCM--digital meter less than a volt often, PCM 5 volts. So even if your meter shows no problem, I think you still have a wiring problem. The truck is telling you that, but you are not listening to the ultimate test instrument for this vehicle-your PCM.
Larry
Old 01-18-2017, 02:55 PM
finn12's Avatar
finn12
finn12 is offline
have a couple of questions. with the pcm disconnected should ground circuit #57 which is pin #25 have continuity with circuit 570 which are pins 24,76,77,103? next question,on the ob2 port does 4 and 5 pins have continuity?
Peter_krazys
1999 to 2016 Super Duty
11-25-2017 11:26 AM
rstroup14
20
05-25-2017 04:13 AM
ballbandit
10-23-2012 11:04 AM
tarheel007
18
01-11-2012 08:39 PM
whitetmw
10-30-2008 08:01 PM
Quick Reply: F250 7.3 deisel hit by lightening!
