E fuel wiring...plow seasons coming
It looks like you have everything hooked up right; I'd remove the Schrader valve and hook the gage directly to the regulator. It could just be plugged or non-functioning. If you have pressure to the one gage, you should have pressure to the other.
You may have already seen this video, but if not it may help you out.
Yup.I totally agree. In the posted pics you'll see the banjo block we built using Komatsu parts.also just discover my brand new Matco fuel pressure powerstroke kit is not even registering air pressure. Just can't trust Chinese built anything. I'm new permanent gauge into Schrader valve now.but there's hope.
Well now that we've solved the fuel pressure problem we're back to our original problem which is crank no start .
if I hotwire the ICP she fires and will take my 3000 pound gauge and whined all the way up past 2500 PSI. When I plug in the new ICP wiring harness I can't get anything when I unplug the ICP sensor I'm getting 250 psi. I'm looking for the next step. It's got a new aftermarket IDM in it. It's got a new aftermarket ICP sensor in it. It's got a new ICP in it ( aftermarket)
That's too high. check out this doc to see if it can help you locate the issue
http://dieselequipment.com/files/281...HPOP-Guide.pdf
#28
My doc has "P1661 Output Circuit Check Signal Low."
This was on another forum.
I found it on another site so I cant really take any credit for it just want to help if I can...
Fault Code: 1661
Circuit Index: PCED
Condition Description: OCC signal low
Comments: Aborts KOEO OCC test
Probable Causes: Low system voltage, internal PCM fault
DTC 1661 indicates that the output circuit check is low.
Possible causes:
-- Low battery voltage
-- Circuit failure
-- Faulty powertrain control module (PCM)
Perform charging system and battery tests.
Is charging system OK?
Yes
GO to «AS2».
No
REPAIR charging system as required.
AS2 VREF CIRCUIT CHECK
Disconnect PCM. Inspect for damaged or pushed out pins, corrosion, loose wires, etc. Service as necessary.
Install breakout box, leave PCM disconnected.
Disconnect manifold absolute pressure (MAP) sensor connector.
Measure resistance from Pin 90 to VREF Circuit 351 (BR/W) at the MAP sensor connector.
Is resistance less than 5 ohms?
Yes
GO to «AS3».
No
IDENTIFY VREF circuit fault. GO to Pinpoint Test «B1».
AS3 VPWR CIRCUIT CHECK
PCM disconnected.
Key on.
Measure resistance from Pins 71 and 97 to the positive battery post.
Yes
GO to «AS4».
No
IDENTIFY VPWR circuit failure. GO to Pinpoint Test «A1».
AS4 PCM GROUND CIRCUIT CHECK
PCM disconnected.
Key off.
Measure resistance from Pins 25, 51, 76, 77 and 103 to the negative battery post.
Yes
REPLACE PCM. RETEST system.
No
REPAIR ground circuit fault. GO to Pinpoint Test «A10».
A10 CHECK PWR GND CIRCUIT CONTINUITY
Key off.
Install breakout box. Leave PCM disconnected. Inspect for damaged or pushed-out pins.
Measure resistance between battery negative post and Test Pins 25, 51, 76, 77 and 103 at the breakout box.
Is each resistance less than 5.0 ohms?
Yes
F-Series, GO to «A11». Econoline, GO to «A14».
No
SERVICE open in PWR GND circuit. REMOVE breakout box. RECONNECT PCM. RERUN Scan Tool Diagnostic Test.
A11 CHECK PCM RELAY
Key off.
Disconnect maxi fuse 9.
Install PCM relay.
Breakout box install, PCM disconnected.
Key on, engine off.
Measure resistance between nonpower side of maxi fuse 9 to Test Pins 71 and 97.
Yes
If fault is still present, REPLACE PCM.
No
REPLACE PCM relay.
Fault Code: 1661
Circuit Index: PCED
Possible causes:
-- Circuit failure
Yes
GO to «AS2».
No
Yes
GO to «AS3».
No
PCM disconnected.
Key on.
Yes
GO to «AS4».
No
PCM disconnected.
Key off.
Yes
No
Key off.
Yes
No
A11 CHECK PCM RELAY
Key off.
Install PCM relay.
Key on, engine off.
Yes
No
REPLACE PCM relay.
#29
Now that we have fuel pressure and I run a scanner code on the old dog it's popped up 1661 tells of a possible PCM problem. Thanks for the information as I'm getting ready to try to test the PCM down but I guess my question is if you were going to buy one what would you all out there recommend. My thought was to send it down to swamps for reprogramming. But are there other options out there that you guys would recommend.
