66 2 barrel carb??
I'm not sure about a 2bbl. There are a few brands/models of 4bbl manifolds that will fit on your engine. Offenhauser and Clifford are two popular brands. If you google
ford 300 intake manifolds
https://www.google.com/webhp?sourcei...ke%20manifolds
You can get quite a lot of hits. Summit and JEGS sell them. Also can be found on eBay.
Here on FTE there is also a forum particular to discussion of the Ford inline 6 cylinder engines, to include the 300. Here
Ford Inline Six, 200, 250, 4.9L / 300 - Ford Truck Enthusiasts Forums
If you really wanted a 2bbl carb you could probably find an adapter to go from 4bbl to 2bbl for use on these manifolds.
Use the Offenhauser 360 along with a Holley 390 and EFI split cast iron hedders. Great combination for good low end torque and highway cruising. The 390 four barrel when tuned will give much better mileage than a 2 barrel and cost about the same.
Depending on where you live you will need to provide a heated spacer under the carburetor as it will ice and freeze.
Garbz
Garbz
blueeyedfordguy
36
01-08-2010 02:19 AM
John 300
10-13-2009 10:52 AM
szepj1
10-24-2003 01:43 AM
