Removing catalytic convertor??
Hello,
I have a '92 F250 ext cab 4x4 with a 7.5L and was wondering if anyone had any advice on removing the catalytic convertor. It has the 2 inlet pipes coming from the manifolds and a single outlet to the muffler. The cat also has 2 approximatley 1" pipes going up to the front of the engine, and I'm not sure what those are for. Can I remove these? What I am hoping to do is cut the cat off and splice in two 2.5" exhaust pipes with flowmasters and have them exit just before the rear wheels. I don't have any emissions restrictions where I'm at so that's not a problem. Any advice would be greatly appreciated. Thanks...
Chuck
Chuck
I would suggest to just either disconnect the tube at the exhaust and leave it open to the air or cut a hole in the new exhaust and weld it in there. That tube runs to the smog pump and pushes air into the cat. So if it is left open to the atmosphere it will just push the smog back into the air....
1986F150six
20
10-03-2018 05:23 PM
WiscoTruckGuy
08-31-2016 06:57 AM
smcdonald001
05-06-2016 08:44 AM
wilsonriverfisher
02-13-2008 01:59 PM
