One week to Truckstock
My truck does not want to go to truckstock . Yesterday I took it into town and on the way back I hit a good size bump , it bottomed out the front springs . The rear float on the Holy carb stuck and truck would only run with the gas pedal all the way down . I nursed it home , and took off carb and cleaned both float bowels . Then I noticed both Alt and ps belts had jumped off . This morning I put on 2 new belts , and took a test drive , as I rolled up my window it jumped out of the track , Alt charging at 13.5 volts so I turn on all lights AC , and wipers . Alt ok but wiper arm falls apart . As I head for home I try and blow the horn to a friend , Doesn't work . Last but not least the gas pedal sticks , new spring fixes that . Starting to think I should bring a car .
