1965 F100 w/1967 289 radiator hose
I am looking for a replacement top radiator hose for a 1965 F100 with what is thought to be a 1967 Bronco 289. None of the local parts stores or online sources have the replacement part listed that matches the upper hose needed. See picture.
Part numbers on the existing hose is as follows: 76EP50 EB D 06096 X129
Have same year 302; swapped the radiator so may not be correct for your application??
If not certain, suggest have local auto parts order for comparison?
Currently have the Goodyear, seem to recall purchased online thru Summit?
Goodyear: 60967 Upper
Goodyear: 60995 Lower
Believe in the past purchased Gates thru Napa auto parts?
Gates: 20860
Gates: 21053
Gates: 20860
Gates: 21053
1966/68 Bronco available with 289, 1969/77 Bronco available with 302.
But the upper radiator hose is not from a 1966/68 289 Bronco as they used a surge tank.
2 upper radiator hoses, one between the radiator and surge tank, another between the surge tank and T/stat housing.
I do know it's a 1965 F100, not sure on the motor. All the replacement parts for the tune-up (plugs, cap, rotor) have aligned to the '67 Bronco 289, having the "large chain" parts store look through their systems and resources. I understand the 289 is universal throughout Ford, so this was a guess using the parts store info. We have done the 'stare and compare' at three "chain" parts stores inventory of hoses, nothing is close enough. I'll get pictures of the block id and post asap. Will have to check the Gates id further, internet searches have turned up empty on the part numbers shown.
pburress
04-19-2013 07:05 PM
