So I have a obs 97 f250. It's had an exhaust leak since I bought it. Changed out manifold gasket and helped a lot. Now I have a leak at the bottom of the manifold or that air tube down there. Been thinking of just replacing with headers. Do aftermarket headers come with the air tube holes or can that all be deleted. Almost positive they will break trying to take out of old manifolds. Any info would be great. Thanks.
Want to know a way to locate a leak in seconds and it works every were every time oil antifreeze gear oil gas transmission vacuum line leaks you name it real easy to locate. And fast. Just click on the name Ultimate above and on profile page click on pitcher to right of page for full description and plenty working pitchers. Better boss
__________________
Ultimate Automotive Leak Detector
What engine? Lots of companies make headers. Banks is best - stainless steel but pricey. You need to make sure header studs aren't busted off in block.
Is it the single air tube off passenger side exhaust manifold or multiple tubes in both exhaust manifolds. If it's a single tube it can be replaced but it's a little pricy. Did mine 3 years ago at $120.
__________________
If your having trouble with finding leaks just click on the tool name Ultimate and scroll down to my web site.
Want to know exactly were it is leaking look up one of my post you will find a tool that can locate every leak you can come up with way easier then trying to here it through a tube.
You've posted the same thing three times with no response. Give up while you're ahead. Also, reported for spam.
According to the list he is a registered vendor, and according to the guidelines he is posting on a thread that could benefit from his services. I think he isn't breaking any rules.
Also, how the hell would it help find an exhaust leak. That sounds like a copy and pasted response he posts whenever he sees something with the word leak in it.
__________________
He's actually got a decent idea for his product....I've gotten him to respond before in other threads, his way of going about things isn't the best sometimes, no doubt.
I've been wondering if he had a legit product and how it works.
