Running rich or lean without cat?
Old 09-08-2016, 12:45 PM
Jim40216's Avatar
Jim40216
Jim40216 is offline
Ive read several post and can't seem to get the answer. On 1994 f350 7.5 the Po eliminated the cat, I eliminated the air pump. The 02 sensor is still in place and no codes, so is it rich, lean or computer compensated?
Old 09-08-2016, 12:52 PM
timbersteel's Avatar
timbersteel
timbersteel is offline
It's running fine from your post.
Eliminating the cat only pollutes the environment more.
Eliminating the air pump won't hurt anything. It was used for dual cats from the factory to heat them up faster on cold starts and burn off the excessive pollutants.
Old 09-08-2016, 01:52 PM
'89F2urd's Avatar
'89F2urd
'89F2urd is online now
The cat and air have nothing to do with afr. High flow cats don't really rob any power...if you upgrade the exhaust, consider using one.
Ardiemus
08-24-2015 12:57 PM
drunkenrich
06-12-2010 05:49 AM
Prplmnsterf150
Exhaust Systems
03-03-2005 08:26 PM
Silver Streak
01-09-2003 09:24 PM
onestep
09-12-2002 04:02 AM
Quick Reply: Running rich or lean without cat?
