In the process of purchasing a 2016 F150 with 20" wheels. I will be putting a more aggressive tire on it and would like to go a little taller without lifting or levelling. I am not concerned about going (much) wider. Any thoughts on size options anyone has on their 20" stock wheels? Stock size is 275-55-20
Reason: Add
Got the tires installed. Went with Duratracs LT285-60-R20. Level is not installed and so far I have not had any rubbing although I probably will install a 2" level because I believe it looks better.
OP -- Those 33" tires are a good match for your F150!
Did the tires improve the ride? Or take from the ride?
