Online Paint Sources
There use to be quite a few local auto paint stores in my area but now is seems they are far and few between. I would like to know if there's an online automotive paint suppler where I can provide the paint code and they mix the necessary ingredients? A 'do it myself' paint job 10 years ago on the 1965 F100; unfortunately, a color not in the Ford Color Wheel, and I have been taking flak for selecting the color since? Primarily just for touch-up for now and paint another color at a later date?
Appreciate suggestions/comments!!
Some times just get lucky!! Rec'd response from TCP, based on info provided they suggest going to the 'Restoration Paint' section on their website where I found a series of drop down menu's; chip code, manufacturer's code, name of paint color, etc.,and it came up with what is supposedly the correct color paint; unfortunately no paint chip to review? Anyhow, placed the order, now awaiting with bated breath; considering the amount of time spent calling, and checking with local paint shops, only took me a matter of a few minutes to locate what I hope is same/similar to the correct paint color?
I do appreciate the referral!!
Send me a Pm, I use a paint supplier via phone and has always been great. i usually give him the color code and tell him how much I need and he makes it ans ships it out. I found him through another forum.
He also has any type of supplies tou will need.
I can't find his website, but I'm sure he will take care of you.
Again, I thank you!!
In a manner of speaking, some times just get lucky! Awaiting delivery of the paint, parked the 65 F100 on the side of the road leaning towards the fuel filler neck. After setting in the hot sun the entire day, fuel seeped out the cap and beneath the paint causing it to peeled from the cap to the bottom of the cab.
Prepped for painting and just applied the 1st coat, TCP color recipe is right on, very pleased. It is Acrylic Enamel, the instructions advises to wait until the next day to apply the 2nd coat??? *** My question: Not sure if I know what 'orange peel' would look like but there appears to be minor flaws in my 1st application; although severity seems to be minimizing as the coat sets up; can I sand between coats, perhaps 400 grit wet/dry??
Again, thanks to U's all for the help!
The paint I had said 2 coats but there's realistically 4 on it. I don't think it hurts to put a little extra on if you have plans of wet sanding and buffing it for some reason when done.
Right or wrong we used a lot less reducer than what it called for and added extra hardener. The paint seemed thin enough as it was and as you can see it laid down very nice on mine with hardly any orange peel.
I hope you haven't sanded it with 800 or 2000 yet.
For color, you should be at least at 400-600 grit.
If the techs say it just needs hardener, then thats all it needs. Maybe a tiny bit of reducer if to get it to lay flatter.
I agree with 74f250, you should at least 4 coats on there, in case you want to sand and buff it later on.
Greatly appreciate the input!!
