keep finding things
keep finding things
i like to just crawl under a new truck and lay there and look.
i discovered today that the 3.5ltt is now a 3.5lttaac.(3.5l twin turbo air to air after cooled) never thought about it being after cooled. when this air cleaner is ready to change it will be replaced with K&N.
I am sorry. On class 8 truck it is called air to air on cars it is called intercooler. I didn't realize it was all that common. My 6.7 had one, just never thought about the 3.5 having one. It does make sense, helps Ford get more power out of it.
LOL, to the OP, I do the same, like to check out how Ford engineered/built our trucks for sure! A bit off topic but...have you guys ever thought about wrapping (insulating) the plastic air intake tubes to reduce heat from the engine bay warming up the intake air, after it's been through the intercooler...I hope that makes sense?
i know the cooler the air the air the better. How about an ac condensor in front of the intercooler, or a little propane injection in to the cooler.
You will regret using the K&N on your turbo'd engine. It lets in too much dust to start with and you will get oil in/on your turbo vanes causing inbalance. Stick with dry filters, you don't need the "extra" flow in a forced induction engine.
Condenser sheds heat. Unless of course the evap is being used for a heat pump then the condenser would be cooling.
well ididn't realize these little TOY turbos were so sensitive, most turbos would burn any oil that made its way to them. The K&N filtered just fine in the 6.7, But that was a TOY diesel compared to what i am used to. How many failures have been reported because of the K&N filter? Just saying ,new to the wonderful world of gas engines (again) didn't realize they were touchy now days.
Most engines can survive more dirt through the intake just fine. It's really a mater of personal preference if you want to choose a filter that COULD let in oil, and WILL let in more dirt. Failures due to this are very uncommon.
Then again, I know guys who don't use air filters at all. And live on dirt roads.
Myself, I don't see the point of using a worse filter when it costs more, but maybe I'm simple-minded.
I've installed cold air intakes on many turbo cars, even some that use these exact same turbos. Never seen an issue with the oil from the filter causing an imbalance on the turbo wheel. I have seen the oil get on the Maf sensor and cause issue though.
That being said, I don't think I'll ever run a k&n filter on another engine of mine. I personally feel like they have to sacrifice filtration for more air intake thus allowing more dirt in the engine. There may be other brands that offer more filtration with a higher air flow though.
