Clutch Pedal Fell off!
Ok guys, I've spent the last year working on my truck on and off, and I got the insurance back on it yesterday and was taking a load of bricks to the dump. It was my first drive with it since changing the transmission, rear end gears, and putting a 4bbl intake and carburator on my 300 I-6. The engine was running great, and I'd made it halfway to the dump and all of a sudden the clutch pedal felt funny, and then the next time I pushed it, it stayed on the floor. Turns out the weld holding the pedal to the shaft broke! It looks like it had really poor penetration in the first place. So, is the clutch pedal just supposed to be welded on? Would one of you guys be able to run out to your truck and have a look to confirm this for me? If so, that is one crappy welding job from the ford factory or PO, that it didn't penetrate.
On a positive note, the engine ran great, and I haven't even tuned the carb yet!
No, Im not sure. That's a good point. So, welding it back together, I should just drill out the existing weld and clean up the outside face of the pedal where the weld currently is, and then should I grind a fillet into the pedal and fill the fillet with weld?
Bste4805
01-12-2014 02:23 PM
ccarrier
13
05-23-2010 08:27 AM
tseekins
03-01-2009 05:52 PM
