1998 conversion van Key fob programming and looking for the connector
Old 09-07-2016, 09:51 AM
pancake52's Avatar
pancake52
pancake52 is offline
Question 1998 conversion van Key fob programming and looking for the connector
Tried programming a new key fob. System won't go into programming mode(doors lock unlock). So I found the module behind the driver side yet there is no extra connector to jump the pin to put it into programming mode. I also looked underneath where the steering column is. Still no luck. It's a 1998 conversion van e150.
Any ideas where the connector is or why it won,t go into programming mode as described in the owners manual? All my other fords work as advertised.
Old 09-08-2016, 07:25 PM
98Econoline150's Avatar
98Econoline150
98Econoline150 is offline
It is to the right of the DLC when sitting in the driver's seat. It is a round two pin connector. Short out this plug with a jumper and the doors should lock and unlock to confirm a fob has been programmed.
Old 09-11-2016, 08:23 AM
pancake52's Avatar
pancake52
COLOR of wires into connector?
i found 1 black unused connector. it has a BLACK wire and a WHITE W YELLOW STRIPE WIRE going into the connector . is that the what i'm looking for?
most posts describe it as white w yellow stripe and a grey w yellow stripe wire. ill check it later and confirm
Old 09-11-2016, 01:40 PM
pancake52's Avatar
pancake52
well it was the correct connector and it does program my first key fob correctly yet the second new keyfob doesn't work. i checked the keyfob batterys and the contacts , still no luck with that one. not sure what to try next.
Old 11-24-2016, 10:34 PM
pancake52's Avatar
pancake52
finally got it working yaa
Old 01-21-2017, 11:56 AM
pancake52's Avatar
pancake52
It did work once I got a good used Oem key fob from fleabay
racefan966
09-30-2023 04:59 PM
darmst
09-28-2022 07:18 PM
PRIMERED79 SHORT BED
12-29-2018 08:40 PM
rjfetz1
1999 to 2016 Super Duty
13
04-08-2009 04:50 PM
Quick Reply: 1998 conversion van Key fob programming and looking for the connector
