saginaw setup for 4.9l serpentine which pulley will work?
I have a 93 f150 and I bought the correct bracket for the saginaw pump and now I need the pulley. I figured I can just buy a rebuilt pump from the store and trade in on of my old ford pumps. That said, I still need to find they pulley but I'm not sure which ones I can use. will any e series van serpentine pulley with a saginaw pump work?
If you are using a E-series bracket, you'll need a E series pump with E series pulley because the Ford corporate power steering pump II (plastic one) shaft is smaller.
On my 94-5.8, when I converted, it was a press off-press, press-on deal. But I was using a replacement late 70s Saginaw which is all but non-existent now in stores.
Also, most of the named parts suppliers will only accept an equivalent core. Just sayin'.
Can you get the pulley where you got the bracket?
Thanks for updating this thread. What alternator are you using? I did the air pump delete a couple years back and had no belt conflict issues, but I'm still using the original 2G alternator. Have plans to go 3G and Saginaw pump - already have everything - just need time.
Weird. Same setup as mine, but I have no belt contact issue. Any pics? I'll try to post some of my setup when I get a chance.
1974 f100
13
05-23-2017 08:52 AM
Don Vito
07-01-2016 12:49 PM
straightsixer
03-09-2013 12:38 PM
packratF350
12-19-2004 07:35 PM
