35" Tire Pressure
35" Tire Pressure
So I just bought a set of 35 12.5 18 Nitto Terra Grappler G2 for my 05 F350. So far I absolutely love the tire, great traction, low road noise, and look awesome. My biggest thing is I don't haul much usually and I don't want them to wear faster than they should considering what I paid for them. I'm at 48-50 psi right now and there seems to be a little bit of tread still not touching the pavement? I was just curious as to what everyone else was running to get the best wear out of them.
2005 F-350 5.4L 6 Speed Manual. Leveled 2.5" on 35 12.5 18.
I used to take kids sidewalk chalk and rub a big line all the way across the tire. Drive forward a dozen or so feet until it starts wearing off. Decrease pressure until it wears off evenly across the tire.
That said, this is for off-road type tires, not highway treads and never with a load. I never went under the safe minimum pressure of (load / capacity ) * ( max pressure). I had ProComp Xtreme A/Ts in 35x12.50R17 and Nitto Trail Grappler 25/70R18s, the ProComps were fine since they were D-Rated I ran them much closer to max pressure for the load capacity (of just my truck empty), but the Nittos had a load index of 129 (4080#), I never ran them under 40psi (out of 80) because they got squirmy below that, even if the load pressure was fine. I was worried about premature wear with them still crowning a little, but they made it 42K miles before I replaced the set due to a sidewall puncture. They still had 6/32nds but they were 4 years old and starting to crack.
Originally Posted by 89LX306
I chalked mine before I got the load inflation table from Toyo and weighed my truck. You would be surprised how close the chalk method got me to the correct psi for the load. It was within 1 or 2 psi.
The math that texastech_diesel shows is the same equation that I use also.
2-many-toys
07-10-2013 08:47 PM
45 ACP
06-18-2010 03:00 AM
