Before you do anything measure the rear pinion angle degree. That way once you do the shackle flip you can remeasure it and can correct it with some shims.
Eric, this is what the front hangar looks like after flipping, also note if your doing this to lower the rear end, that 2-3" here will only net about a half to 1" at the axle...
Good luck
So, what I did: I had the tire shop install some skinny 235's on the front, now it looks level and I can steer it to park! Great suggestions all, thanks.
Eric
