1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Death Wobble
Old 09-03-2016, 04:18 PM
Greynomad's Avatar
Greynomad
Greynomad is offline
Death Wobble
2013 250 DL 4WD
started about a year ago with 60K on the odometer. Initially had all of the u-joints replaced with new bushings. The wobble was back at 65k so had the ball joints done. About 4k later the wobble is back. Had the wheels balanced and rotated at Les Schwab and the alignment checked. The wobble happens when I hit a serious bump and if I am towing the fifth wheel ..... bloody terrible.
I just wonder if it is in the steering box....? There is no slop in the steering and the truck tracks straight.....
Old 09-03-2016, 06:46 PM
SHAWZER's Avatar
SHAWZER
SHAWZER is offline
Stock height or has it been lifted ?
Old 09-03-2016, 08:34 PM
Hotrod70d's Avatar
Hotrod70d
Hotrod70d is offline
Death wobble occurs when some part of the suspension is worn out , it could be as small as a track bar bushing or a ballpoint . You may end up taking the whole front end apart to find it but something is worn out.
Old 09-03-2016, 09:16 PM
Pocketlint's Avatar
Pocketlint
Pocketlint is offline
Originally Posted by Greynomad
2013 250 DL 4WD
Well so like you already replaced some parts, but your saying it is still there. Did you replace those parts or did an auto place or dealer tell you to try fixing some of those things? Just curious as some folks who have encounter the wobble have tried different things and replacement parts.
Old 09-04-2016, 04:51 AM
Greynomad's Avatar
Greynomad
I had the front end lifted 2" to compensate for the installation of a 50 gal tank in replacement of the original 26 gal tank that came with the truck. I have air bags in the rear.
All of the work was done by various shops.
Old 09-04-2016, 07:17 AM
Hotrod70d's Avatar
Hotrod70d
A lift does not cause it. I have a lift no wobble, your track bar, pitman arm ,may be worn out, or tie rod ends . You have wore out parts somewhere .
nickt916
11-04-2013 08:46 PM
A/Ox4
04-03-2013 10:29 PM
FordMaverickFan
12-19-2012 05:58 PM
F250_
11-19-2012 08:19 AM
robin1t2002
1997 - 2003 F150
10-07-2008 05:05 PM
Quick Reply: Death Wobble
