what gears for a 400 c6 half ton.
Hello,
Just wondering what gears the 400 /C6 would have in a half ton from the factory. I have a 72 with a 400/c6 and it has 3.70 gears. It had a 302 c4 in it.
What gears would give me good mileage and not be a dog. Its mostly a cruiser/ summer time truck.
Thanks Pat.
Thanks Pat.
Agree around 3.50 would work well as an all around gear with the 400. Also it depends on tire diameter and usage. If you are stock or a just a bit bigger in tire size around 3.50 should allow her to cruise up to 70 or so and have decent acceleration and moderate towing capability. If you are running taller tires... say 30"+ the 3.70 should be fine. If highway driving is not a priority, I'm not sure changing the 3.70 is worth it. With smaller tires, more highway use and limited towing 3.25 would be best though acceleration would suffer.
Good mileage with a 400/C6 in a 72 F100 is going to be relative. As compared to a F250 4x4 yours will get relatively good mileage, compare it to a thirty year newer truck and its not so good.
Just for driving, the 3.25 wouldn't be bad.
You could even set up two different gear sets for your nine inch, less than an hour and you can swap them out. Don't forget to refill with gear oil.
Robert
Robert
mse871859949
01-21-2014 07:47 AM
f150light
11-14-2012 12:33 PM
emeraldcoupe
02-05-2010 08:05 PM
