Corrugated hose cover causing damage to intercooler tube.
More of a PSA. I've had this truck for 6 years now and noticed these corrugated lines sitting on the tube while doing my oil change. I expected them to be melted a little so I figured I'd check on them and it turned out to be the exact opposite I'm glad I noticed this I'm not sure how much longer before it would of made a hole.
The image doesn't do the depth justice.
Wow. Its hard to believe that PLASTIC can do that much damage to metal tubes, without long since turning to dust themselves. What is that plastic made out of to be so abrasion resistant?
I dunno but they should of made the tube out of it
FWIW, the Ford replacement tubes are steel and not AL like came with the truck.
On my phone so I can't see everyone's signature, but I think only 99's came with aluminum CAC tubes. I know my E99 had the same wear marks from the corrugated wire loom but my 2000 has steel tubes and no wear marks.
