Short bed 4-door diesel project
#32
Leroy is off base on almost everything he said.
Rust-Mort is (and always has been) phosphoric acid based.
read the SDS... https://www.semproducts.com/rust-and...rs/rust-morttm
Hydrochloric (muratic) acid leaves iron &steel with NO coating and the corrosive cloud of vapor will travel downwind getting into places you have no way to protect.
While Rust-Mort is great for brush application, I find Ospho (or generic) in a cheap pump sprayer much easier to cover everything.
Fluidfilm is lanolin based iirc and doesn't seem to have any of the drawbacks of undercoating.
Bulk sheep grease and petroleum jelly are pretty cheap to mix with a gallon of odorless paint thinner and spray on.
I want to find a wand that sprays 360* so i can get down either side of the cowl and up inside the A pillar
This is a really cool project.
Thanks for taking the time to share It here on the forum.
Eastwood Internal Frame Coating 14oz Aerosol
I have used it on a 1 year only hood between frame & skin to keep it from rotting out. I will also use it on the "A" pillars, a long the roof skin and inner frame, rockers and rear wheel wells to stop rust / rot.
I have also used this on my car project where I can get a paint brush at.
Eastwood Black Rust Encapsulator - Paint Over Rust
Dave ----
#33
#34
Chris sent me a better image of the medium duty truck interior. You can see the door trim panels much better. The black pin stripe is clearly visible, as well as the speaker grille. Notice that all of the instrument gauge needles are WHITE. The 3,500rpm tach that I got from David has a white needle as well. Not faded, but painted fluorescent white. It looks sharp. I don't think it would look particularly good on my diesel cluster with the red/yellow tach zones, but for a regular cluster it is an interesting alternative to the fluorescent orange.
#35
#37
X2
There's always Cosmoline (except in California)
Cosmoline - Industrial Grade Long-Term Rust Preventive | Cosmoline Direct
I don't care for the smell but it works and is easy to apply.
#38
Gary, the more I think about it the more I am leaning toward doing just that. It seems really lame to buy it and not put it in my truck, but this is a "user" vehicle that will have to be parked outside. The Arizona heat and UV is absolutely brutal on paint and plastics. I was looking at my F700 aluminum radio bezel that baked into a dull grey chalky mess and wondering how long the NOS bezel would stay looking nice. Throwing a blanket or towel over the dash when parked would certainly help, but maybe a cloned stunt-double would be an even better answer.
#40
Gary, I am starting to wonder if the white needle gauges came with the custom cab silver bezel trucks only. Notice in the pic above that the 3,500rpm tach has an orange needle. The NOS 3,500rpm tach David spotted on eBay has an orange needle. The 4,000rpm tach and 4,500rpm tachs David has both have orange needles. However the 3,500rpm tach in the brochure and the one David sent to me have white needles... coincidence?
#41
#43
#44
[QUOTE=Ford F834;16593852]I will second that... the four-spoke wheel looks awesome but I have never seen one. All the medium duty trucks I have seen have two-spoke steering wheels like this:
Jonathan, what is the switch to the right of the headlight switch? It looks like transfer case? And, it is mounted similar to where the factory Fog light switch would be.
#45
[QUOTE=1986F150six;16594557]
This isn't my image, but from what I can make out it is a split rear axle high range/low range switch.
