AIR VENT DOOR SCREW SIZES??
Old 09-01-2016, 02:11 PM
tractormanbill's Avatar
tractormanbill
tractormanbill is offline
tractorman
What type of screw and what size holds the air vent screen down to the cowl and what holds the vent cover to the frame? I had help tearing mine apart and storage must have eaten them up!
Thanks in advance.
TractormanBill
Old 09-01-2016, 10:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Bill, they are round-head sheet metal screw, probably a #6, probably 1/2" long. They aren't listed anywhere I can find in the parts manual, if no one else can tell you I'll pull one out for you.
Old 09-02-2016, 03:02 PM
tractormanbill
tractorman
I picked up a hand full to try this weekend.
I have the old F-7 donor but I'm too old get up on it to take them out.
I may send one of my boys up there with a screwdriver.
Thanks Ross,
Bill
TractormanBill
Old 09-02-2016, 03:21 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
be careful with the cowl vent screws, just loosen them up enough to slide the vent over on the vent frame work (the frame has slot openings) and lift the cowl vent off the frame.
if you try to unscrew the cowl vent screws all the way they may break off in the vent. (at least mine did the first time i removed a vent) Im not sure how or why that happened but I assumed the screws were just rusty and that's what cause them to break?
or maybe they designed it that way??
Old 09-02-2016, 03:35 PM
tractormanbill
tractorman
Thanks for the suggestion, I have everything soaking with screw loosener.
Bill
TractormanBill
Marten
04-26-2019 09:02 AM
jvmcc
06-11-2016 06:22 PM
Chevmn56
04-18-2013 01:19 PM
66fordf100
01-30-2004 11:11 AM
Quick Reply: AIR VENT DOOR SCREW SIZES??
