Common? Coolent Leak
So instead of going all in last winter I tried to cheap out on the rebuild of the '49 Flat head.
It runs like a watch, smooth....
However, I am loosing coolent, I'm pretty sure it's going out the exhaust as the tail pipe is wet. What would be the most likely place? Cracked head or Block? I am pretty sure it's not the head gasket as I replaced it and checked the heads and block for flatness with a straight edge.
There is no oil in the radiator, There is no water in the oil. I have a 4psi cap on a new radiator, there are no exterior leaks.
Thanks for the input!
Have you run the truck on the road, enough to get the engine to operating temperatures, burn the plugs clean? If so, you can pull the plugs and if a coolant is going into a cylinder the plug will look a lot different than the plugs in a normal environment. As mentioned, do you have a recovery tank?
You might ask a local engine rebuilder if they have some blocks of block sealer you could buy...We used to get reman engines and every one had a cube of black whatever it is in the water pump area. I can't remember one that had a water leak. A quart a week is a small enough leak it just might fix it.
Did you use your original cap on the radiator? Some replacement radiators have a different dimension between the top and bottom sealing surfaces. I found with my new radiator using a modern radiator cap vs my old one worked better. The pressure of the cap just changes the boiling point of the radiator fluid which helps prevent water pump cavitation. But if you are running a stock flathead that shouldn't be a big deal. Of course it does raise the pressure in the system but only by the difference in the cap rating (10 psi?) which isn't much and should be OK as long as your hoses, etc. are in good condition.
Beating the Heat: Advantage of a High Pressure Radiator Cap | Tuner University
Controversial I'm sure . . . let the "venting" begin
It is a new aluminum radiator, with a new 4 psi cap. If you fill to the top in will push coolant into the overflow bottle.
Had a friend follow me around yesterday and he said there is some white smoke and you can definitely smell anti freeze, So we know where it's going, out the exhaust, now what to do?
joestratton1
12-07-2008 03:02 PM
vinnyf350
09-28-2006 01:43 PM
vinnyf350
09-28-2006 01:09 AM
Guitar_Stitch
03-30-2005 07:25 PM
