2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Platinum ETIS Data shows "Less Electronic Locking Differential"???:
Old 09-01-2016, 04:26 AM
Wealthk1's Avatar
Wealthk1
Wealthk1 is offline
Question Platinum ETIS Data shows "Less Electronic Locking Differential"???:
Good Morning All...
My build data showed up this morning and I found a few curious items but one stuck out- "Less Elect Locking Differential". It shows the Electric Transfer case and Auto Hubs, but will it have the "Pull ****" function to lock the rear as on my 2014? Build is a Platinum F350.
Here is the ETIS List:
* Illustration shows model only
F-Series Super Duty, 6.7L 4V V8 T/C Diesel, Absolute Black
VIN Number: 1FT8W3BT0HEB32345
Primary Features
Build Date: 28.08.2016
Vehicle Line: F-Series Super Duty
Body Style: Double Cab (3/4 Door)
Version: 350 Series
Engine: 6.7L 4V V8 T/C Diesel
Transmission: 6 Speed Auto Trans (6R140)
Drive: LHD 4WD (PTD)
Axle Ratio: 3.55
Emission: 50 State Emission Requirements
Air Conditioning: High Capacity Air Conditioner
Territory: (+)"USA"
Paint: Absolute Black
Minor Features
Ebony Interior
With Rear Mudflaps
Front Scuff Plates - Illuminated
Less Front Fenders
With Front Mudflaps
DEC-FX4 O/RD SRW Silver/Red
Tailgate - With Flexible Step
Tailgate Applique - Bright
With 6 3/4' Styleside Steel Box
4 Cargo Tie Down Hooks - Inside
Less Pickup Box Extender
Spray In Load Box Bedliner
Bed Ramps
With Base Payload Package
160" Wheelbase
Premium Version
(-) Version Packages
Kentucky Truck Plant Build
With Snowplow Pack
Pickup
Trailer TMPS/Camera Prep Pack 1
11,500 LB. GVW
Less Appearance Group
Exterior Appearance - Level 1
With Power Equipment Group 2
With Memory Package II
Feature Content Group 1
Kentucky Truck Plant Build Only
With English Language Label
Owner Hand Book Pack
Brand Owner - Ford
With 2 Ton Mechanical Jack
With Power Front Windows
With Electric Rear Windows
With Privacy Glass
With Power Sliding Rear Window
With Heated Rear Window
WHEEL WELL LINERS - REAR
Standard Ovrhed Console & With Rail
Hi Line Cubby Box - Leather
Floor Mat Kit Level 1
Memory Adjustable Foot Pedals
Front Floor Carpet Mats
With Rubber Floor Cover - Premium
With Illuminated Sunvisor - Drivers
With Illuminated Sunvisor-Passenger
With Level 4 Door Trim Panel
With Power Deployable Running Board
With Satin Aluminium Grille
Less Exterior Wheel Lip Moulding
Autodim RV Mirror W/AHBC/LKA
Dual Sail T'Scp TT Mirrors-Pwr/Htd
Exterior Mirror Finish - Chrome
With Driver Seat Back Map Pocket
Passenger Seat Back Map Pocket
Less Front Seat Centre Armrest
With Rear Under Seat Stowage Bin
With Front 4 Way Headrest
Rear Centre Armrest With Cupholder
With Drivers Power Lumbar Support
With Passenger Power Lumbar Support
Driver/Pass Multi - Contour Seats
With Drivers Heated And Cooled Seat
With Pass Heated And Cooled Seat
With Heated Rear Seats
2 Row-H/Ser Flip Up W/Elon Cushion
Drv Power Seat Adjust With Memory
With Pass 10 Way Power Seat Adjust
Trailer Tow Prep Pack
With Trailer Towing Attachments
Fifth Wheel - Fleetmaster - Fixed
With Chrome Front Tow Hooks
With Trailer Sway Control (TSC)
Gooseneck Hitch Kit
Less Fifth Wheel Hitch Kit
Cleat Tie-Down Kit B
With Chrome Exterior Door Handle
Chrome Liftgate Handle
With Remote Controlled Tailgate Release
Frequency - 902 MHZ
With Central Locking System
Keyfree System
Keyless Entry/Start - Passive
With Automatic Windscreen Wiper
Vista Front Power Tilt/Slid/Fixd Rr
Less Tu-Tone Accent Colour
Less Body Tu-Tone Paint
Front Bumper Painted In Bodycolour
Rear Bumper Body Coloured Painted
With Front Licence Plate Bracket
Side Air Bag - 1st & 2nd row
Less Rear Seat Belts
Adjustable'D'Ring-Drivers Seat Belt
With Passenger Air Bag Deactivation
With Adjustable 'D' Ring Pass Seat
With Frame Mounted Tyre Carrier
Less Chassis Frame Extension Pack
With Conventional Spare Wheel
Tyre Pressure Sensors - 315 MHZ
Premium Off Road Frt Shock Absrbers
Premium Off Road Rr Shock Absorbers
With Single Rear Wheels
20 X 8.5" Polished Alum Wheel
Less Wheel Covers
With Bright Wheel Hub Cover
Locking Wheel Nuts
With Standard Engine Cooling System
Less Engine Idle Shutdown Timer
Immersion Heater Engine
With Remote Starter
With Monobeam Suspension - Narrow
Less Stabilizer Package
Less Attitude/Ride Height Pack
With Standard Duty Front Suspension
With Front Stabilizer Bar
Single Leaf Rear Auxiliary Spring
Less Rear Stabilizer Bar
Less Rear Axle Package
3.55
With Chrome Exhaust Pipe Extension
Power 4-Wheel Disc Vacuum Boost
Integrated Brake Control
4 Wheel Anti-Lock Braking System
Roll Stability Control Brk W/Betc
Normal Fuel Fill
Less Tracking System - FIA
Less Transmission Power Take Off
Electric Trans Case And Auto Hubs
With Skid Plates
With Mid-Ship Fuel Tank
Fuel Cap - Non Locking Green
With Diesel Fuel Capability
Less Gaseous Prep Pack
With Low Sulfur Diesel Fuel Content
Active Steering
Power Tilt Memory Steering Column
With Luxury Steering Wheel
With Heated Steering Wheel
Less Electronic Speed Limitation
Adp Spd Cnt-Coll Mit & FWD Sns
With Supplemental Air Heater
With MPH/KMH Speedometer
Tyre Inflation Monitor
With Compass Display
MFD TFT Touch Screen
With Navigation System
Customer Info Display-Pack 3
Lane Departure Warning System
With Reverse Proximity Sensor
Blind SPT Monitoring W/Trailerng
Enhanced Security Alarm
With Safeguard Anti-Theft Sys(Pats)
Heavy Duty Battery
Dual Extra Hvy Duty Alternator
110v Alt Current Oulet-In Cab
Elect Prem AM/FM Stro/Disc/Clock
With NAAO Radio Frequency
HD And Sirius Radio Broadcast
With 10 Speakers
Sync III
With Universal Garage Door Opener
Less Auxillary Lights
Headlamps - Fixed DSS (LED)
Daytime Running Lamps Level 2
Headlamps - U.S. Symmetry
Front Fog Lamps-LED
With Spot Light
Roof Marker/Clearance Lights-Conv
With Right Hand Spot Light
Lighting Package Level A
With Ambient Lighting-Interior
Tail lamps - LED Rear
LED High Stop Lamp W/Cargo Light
350 Series
F250/350/450/550 Super Duty
Old 09-01-2016, 05:45 AM
Larietpsd's Avatar
Larietpsd
Larietpsd is offline
I do t think the duallies have e lockers!! All limited skips
Old 09-01-2016, 05:57 AM
Wealthk1's Avatar
Wealthk1
Wealthk1 is offline
Question Mine is an SRW...
and the window sticker has the fourth item as 3.55 Electronic Locking axle...
That's why I was questioning the ETIS data....
Old 09-01-2016, 06:31 AM
archerseven's Avatar
archerseven
archerseven is offline
My 250 showed the same. Maybe THAT's why it's on hold? I wasn't too worried because the window sticker was correct.
Old 09-01-2016, 06:38 AM
System's Avatar
System
System is offline
Prolocutor
Received 1,183 Likes on 568 Posts
I wouldn't worry about it. Lots of trucks are showing "less front fenders." I'm fairly certain they are getting them. If it's on your sticker it will be in the truck.
Old 09-01-2016, 07:48 AM
Wealthk1's Avatar
Wealthk1
Wealthk1 is offline
Archer,
How do you know your truck is on a hold. Where do I see that?
Thanks,
Bruce
Old 09-01-2016, 07:50 AM
archerseven
Originally Posted by Bruce J. Smith III
Archer,
Thanks,
Bruce
Dealer told me. He said expected release 9-25. More details in this thread... https://www.ford-trucks.com/forums/1...reat-news.html
Old 09-01-2016, 07:56 AM
Force74's Avatar
Force74
Force74 is offline
Maybe the locking diff is an issue guys. Mine didn't have one, but it seems most of you guys did order one. Ordered mine 6-10 and its supposedly in transit.
Old 09-01-2016, 08:28 AM
Wealthk1's Avatar
Wealthk1
Wealthk1 is offline
I just got off the phone with the dealer and the truck is ramped at Kentucky with no holds. It's on the sticker, so I'm not real worried, just wanted to let people know what i saw.
Thanks all!
Bruce
Old 09-01-2016, 08:33 AM
J-MAN8880's Avatar
J-MAN8880
J-MAN8880 is offline
When I was using ETIS while shopping for used trucks, I noticed that almost every truck I looked at said less E-Locker for what ever reason. It would be on the door and window sticker, but not ETIS? Just some odd anomaly.
Old 09-01-2016, 09:02 AM
Kenv's Avatar
Kenv
Kenv is offline
Also...looking at your list....there is no Absolute Black color...on a Platinum.....Don't take that list for accuracy.
Old 09-01-2016, 03:19 PM
Blk04Snake's Avatar
Blk04Snake
Blk04Snake is offline
It also comes "With 6 3/4' Styleside Steel Box" so I wouldn't get too worried.
Old 09-01-2016, 08:30 PM
17 Oaks's Avatar
17 Oaks
17 Oaks is offline
I am trying to order '17, 6.7, KR, CC, LB, SRW and it seems to be forcing me into: 3:31 NON Limited slip, WTH???? every other box I check wants to change to DRW or the gasser engine.
I want to go with a locker or at least a limited slip in 3:55 or 3:73.
I cannot imagine a 3:31 with the 6.7 and not limited or locker and trying to parse 860 lbs of torque to the street,,,INSANE!
anyone have any insight on this???
Old 09-02-2016, 05:16 PM
17 Oaks's Avatar
17 Oaks
17 Oaks is offline
Just looked at a F 250 '17 with a 3:55 Locker and diesel
texinwa
1999 to 2016 Super Duty
05-21-2018 04:56 PM
muj0
2015 - 2020 F150
21
04-12-2017 01:01 PM
archerseven
2017+ Super Duty
07-27-2016 11:32 AM
Kamstutz
07-28-2013 10:36 AM
02 Super Duty Guy
06-20-2013 09:40 AM
Quick Reply: Platinum ETIS Data shows "Less Electronic Locking Differential"???:
