My 95 bronco idi build
Old 09-10-2016, 10:12 PM
Jay54's Avatar
Jay54
Jay54 is offline
The family and I went to Pacific city, Oregon and had a church bbq and played on the sand.
Idioit you got lucky with that plug. Here is a pic of #8 piston, same cylinder that has all the water marks. Whats even more amazing to me is how much I can move this piston in the bore...
So this core block being junk setback kind of slowed my motivation down but I pushed thru. I ordered the camshaft from R&D Thursday night and I got the turbo pump on the F350 Friday night and started it up this evening. It runs so much better then the worn out pump that was on there...
<a href="http://www.supermotors.net/registry/media/1096294"><img src="http://supermotors.net/getfile/1096294/fullsize/trim.ab7cc0dd98be4c099d8e922fd4eac61d.mov" />It's Alive!!!</a>
Old 09-25-2016, 11:18 PM
Jay54's Avatar
Jay54
Jay54 is offline
The tps on the gas engine failed last week on me and the truck lacks power in my opinion. So I replaced the tps (shifting and idle issues) and blocked the egr with a pop can. Part throttle was much better. I wanted to move the intake air temp sensor to the air box but didn't get around to it. All this so I could tow my quads on the sand and play!!!
Old 02-09-2017, 01:38 AM
Jay54's Avatar
Jay54
Jay54 is offline
I haven't installed the IDI yet. I decided to build my shop first.
I have done a few wheeling trips since, snow and mud...
Plan on the diesel after shop is done.
Old 04-05-2017, 01:49 AM
Jay54's Avatar
Jay54
Jay54 is offline
So went to Browns camp on the 25th of march and hit a few trails by lyda camp. Ever since the radiator blew out the BKO would pump white smoke out the tail pipe at idle... So needless to say I watched my temp gauge at all times. Also unbeknownst to me the driver M/M was shot. The fan came up and rubbed the radiator hose, made it back home with duck tape and zip ties... So I started the tear down finally.... Some pics
Trying to get to 7 up from lyda camp
Out with the gasser!!!
Some insulation. More on the hood to come.
The diesel radiator, I have it so I'll use it...
Old 04-12-2017, 03:43 AM
pgg00's Avatar
pgg00
pgg00 is offline
Happy to see the project started now. I remember doing the same teardown when i did my swap
Old 05-08-2017, 01:52 AM
Jay54's Avatar
Jay54
Jay54 is offline
Thank you, The 7.3 IDI is so much dirtier then a cummins!!! So the engine is almost completely together. Question about valve springs, with the stock turbo setup and R&D camshaft can I get away with stock valve springs? Gears are 4:56 with 35" tires
Old 05-08-2017, 03:07 AM
88 Ford IDI's Avatar
88 Ford IDI
88 Ford IDI is offline
With the cam upgrade, I would upgrade to Comp 910 valve springs. Don't want a valve hitting a piston...
drptop70ss
05-26-2019 05:45 PM
Jaime74656
12-25-2015 08:53 AM
1985 Bronco
08-09-2014 01:01 PM
rpenterics
1978 - 1996 Big Bronco
03-27-2006 10:10 PM
ddwood55
General Automotive Discussion
15
10-09-2004 02:10 AM
Quick Reply: My 95 bronco idi build
