Transmission voodoo - where to begin?
I removed the 17mm by simply unthreading it counterclockwise. It came off pretty quickly.
Then I moved to the other side, and with an 18mm wrench began to tighten it, thinking that it would pull out by slowly tightening it. It hasn't come out, however - and now it's super tight. Almost as if I'm really tightening it right in place. It's taking a tremendous amount of effort to get ANYTHING to happen, and at this point, I'm afraid I'm just sucking it tighter and tighter - but it's no closer to actually coming out.
Does this shifter look like what you'd expect to see on a M5OD? Am I even headed down the right road?
I have a feeling that I'm close, but just not there yet.
Appreciate any input - as always, you guys are lifesavers!
Thanks Lead -
I appreciate you posting that video; I watched that one earlier today. However, as I referenced in one of my many posts - that shifter doesn't match the shifter in my '89 F150. It's close, but not a match. I think the youtuber mentions that his is a......'99 F150. Close - but not identical.
My shifter had nuts on both sides. You can read what happened when I tried tightening one side. No dice. Am I being impatient?
I apologize about the many posts; I can't seem to post multiple images in one post when posting from my phone. Our rural internet is so crazy slow that I have to post one at a time. I'll see if I can clean that up in the future. Sorry about that posting mess....
Keep the good info coming! I can use all the help I can get. I'm on the WWW now looking for even further details. Hopefully I'm close....I thought this was a quick and easy job! Haha! Famous last words! hahahah
I read in another thread that perhaps I can simply remove the entire assembly by taking out the three torx screws and removing the entire shifter assembly. Is that true?
Perhaps I'll try that and see where it leads me....
#28
#29
#30
When you put it back together, throw out that second nut. It doesnt do anything, whoever put it back together probably just thought they missed it and found one to install.
