2003 F250 V10 Temp Gauge
Hello, I have searched the forum for my problem and have found some similar
but mine is a little different. Truck has 210K miles, I have had it since 30K. No issues but a radiator change at 130K and two blown plugs/coils. I live in Florida and running the AC all the time an issue developed that the temp gauge pegged instantly at idle while in drive and went into limp mode. Truck was shut down for 5 minutes and then no problems. This has never happened when the truck is moving. If I see the temp gauge start to go up all I have to do is let off the brake and it goes right back to normal. This is very intermittent and may not happen for three or four days at a time. I tried idling with the heat on and Cap off and it did it too. Also at idle with no AC on instead of pegging hot, it pegs cold. Should I try the T-stat first, or is the issue a sensor since it also pegs cold? Any help would be appreciated, as this is my families only vehicle at this time.
Ford Truck Enthusiasts Forums - Search Results You will have to read through the posts for a fix. It could be a sensor issue, but this will give you some information on the symptoms and repairs of the system. If you do a search, either forum or site, you can retrieve very valuable info on whatever your issue is. It will require time and reading though.
ipacific
11-15-2006 02:54 PM
