Boost Leak, Need Help!
I have been informed by my friends that my wastegate is not opening when I let out of the throttle, it's just whistling back down, I took my friend for a ride, and he said the truck wasn't building near as much boost as it should. I've bought the materials required to build a boost leak detector. Do y'all have any ideas what my problem could be? Wastegate issues? Turbo? I just want my truck to run like it should.
Thanks,
Caleb
Thanks,
Caleb
on
1 Post
In stock form, you're not going to get much turbo surge. And depending on the intake, it will sound different. The 96 OBS trucks sound a little different than the SuperDutys as well. Without boost readings, it's tough to know what's happening just by listening to it, or describing it over the internet.
on
1 Post
Won't hurt a thing, but don't expect to see much more than a 50 HP gain with it, even though it will have like a 140 HP tune as it's hottest tune. You will wanna go ahead and get that Pyrometer if you chip it, and if you ever go with any other mods like bigger injectors and turbo, you will wanna get custom tunes on the chip. With a stock truck, the canned tunes that come on the chip will do fine. It will wake it up a little.
derek0525
13
01-19-2016 03:57 PM
UP_There
12-04-2008 06:10 PM
