03 F350 6.0
03 F350 6.0
I just bought my first Powerstroke. Its a 1 owner with 70k miles all original except 4"exhaust. I'm going to be towing a 10k lb 5th wheel to local races and some in town driving only. My question is after reading a lot of forums I have mixed ideas as to what upgrades or repairs should be done to prevent Engine damage from Egr and related areas that are known to this truck? Not looking to spend 10k on it but dont mind doing whats necessary considering I can do all the labor. Thanks for any advice and glad I found this forum.
Buy a gauge, baseline your values, and don't fix what isn't broken:
https://www.ford-trucks.com/forums/1...eral-info.html
This is an older list that needs some updating, but focus on Stage 1 and 2 here before you start changing out engine parts:
https://www.ford-trucks.com/forums/s...09&postcount=6
6.0L Tech Folder that thread came from:
https://www.ford-trucks.com/forums/3...ch-folder.html
6.0L engine forum:
https://www.ford-trucks.com/forums/forum107/
6.0L engine forum:
Found this thread by accident while researching something else. I do not own a 6.0, however, my friend has an '06 with a 6.0. The all talk about a bullet proof kit that takes care of the egr issue as well as a few other known issues. Having it installed was over 3000 bones, but he did it himself for around 750.
Delete the EGR valve
Replace the oil cooler
Flush the coolant system. I replaced with ELC coolant.
Change oil and both fuel filters
Keep up on oil changes...I like 5k intervals.
This was always the first things I did to my 6.0's.
There is no reason to replace the oil cooler unless it's clogged. To know this you need an obdii gauge. Flushing the cooling system and going to elc is a good idea unmaintained ford gold coolant will cause a pretty good mess even in a gas engine but do not use the chemical flushes unless your going to do the oil cooler because it will clog it up. Lots of 6.0 have gone lots of miles with the egr system in place that being said is it overall better for the engine to not have the egr you bet, but you can't just take the valve out and call it good the cooler needs to be removed also. Then you have the whole argument about leaving the valve plugged in place for proper cooling fan operation with the cooler removed or just using a block off plate in place of the valve or the combination of leaving the valve plugged in but covering the hole with the block off plate. If you have emmisions inspections where you live you can't just get rid of the egr system. You can also turn the valve off though tuning and leave everything in place but before you have it inspected you will need to tune it back. Same goes for removing the cat and using a delete pipe. The most important thing is for you to know is your temps that will tell you where you need to start. Scangauge II edge insight or one of the smartphone apps and Bluetooth obd adapter or if you want a tuner the sct livewire does it all and sct is the way to tune these trucks.
Intake O-ring bad.
I found the Oring leaking today between Intake and Front cover so I bought one at the Dealer and loosened intake to slip old one out and slipped new greased up one in and put back together. Going to flush engine but no chemicals and I read that the Zerex G05 was a good coolant? Changing oil with Rotella and bought all Ford filters, oil,Air and both Fuel Filters. Ordered a Obd 11 Bluetooth adapter to check EOT and ECT parameters. Thinking of deleting EGR because of the trouble and we have no emissions checks in my state. I hate to buy a $500 tuner and not sure of the talk about fan wires? Any other suggestions while I'm in there? Thanks for helping out the new guy.
Very Good Info.
Ford Truck Enthusiasts Forums - View Single Post - Just bought 06 F350 FX4 6.0!!
6.0L engine forum:
6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
6.0L engine forum:
Let me restate, I mean delete kit for the egr, not just the valve. Replacing the oil cooler while you are in there is a good idea. I have been around a lot of 6.0's, I feel it is a very good, rather inexpensive safeguard. Your oil cooler could be beginning to clog, due to the existing egr system or coolant contaminants.
I purchased my deletes from River City Diesel back in the day, they were also good about answering questions about my 6.0.
This is what I would get today:
https://www.rivercitydiesel.com/inde...ed=1&Itemid=54
