Ignition...Dang that thing is HOT!
Old 08-31-2016, 12:22 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
To check Rods idea about dirty contacts in the relay, it would be simple enough to jump 12 volts to the relay & check resistance thru the contacts with an ohm meter. If you read high resistance theres the problem
Old 08-31-2016, 12:43 PM
theRedEx's Avatar
theRedEx
theRedEx is offline
Good idea. I now have something to do when I get home this afternoon.
Thanks!
Old 09-01-2016, 11:06 PM
Mikeman's Avatar
Mikeman
Mikeman is offline
Hard to argue with shorod, but before you replace the relay, you could just remove it and see if there's any corrosion on the relay prongs/pins and the socket. Sometimes, just removing and re-installing is just enough to clean it up or you could use a Scotchbrite. There could be high resistance where the relay plugs into the box. Just a thought...
Old 09-02-2016, 07:07 AM
shorod's Avatar
shorod
shorod is offline
And definitely a good one!
Old 09-05-2016, 09:34 AM
theRedEx's Avatar
theRedEx
theRedEx is offline
I checked the relay, it was nice and clean, that would have been a cheaper and easier fix than...
So, on the way home from work that day, I was turning a corner and I gave it some gas, I got chugging instead of pickup. I still checked the relay, although at this point, I started leaning towards that wretched fuel pump in the gas tank that has to be dropped to gain access.
Fuel Pump Assy - Check
Fuel Filter - Check
Busted Knuckles - Check
Fixed Ex - Check and Check!
Had a 20% discount at Advance, so I managed to save myself about $50 on the deal.
Thanks to everyone for their help, an ear for listening, and a shoulder for crying!
Old 09-06-2016, 01:36 AM
87 XLT's Avatar
87 XLT
87 XLT is offline
Congrats on finding the problem & thanks for the update.
Ford SD
09-21-2016 07:48 PM
SeannyBoy84
Modular V8 (4.6L, 5.4L)
07-01-2009 08:31 PM
billsdaddy
07-05-2005 07:23 PM
95Explorergirl
07-13-2004 12:56 PM
fleeson
1983 - 2012 Ranger & B-Series
08-28-2003 10:22 AM
Quick Reply: Ignition...Dang that thing is HOT!
