Roofrack Maximum Load?
On my old E-350, I installed 4 heavy duty cross bar racks. Each one was positioned directly above the wall studs ( or body ribs) and had 8" triangular gussets distribute weight in the rain gutters. Used all Grade 8 hardware. We needed a-lot of 1 1/2" steel pipe on a jobsite and nobody could deliver it until the next week. I had them set about 1800 lbs. of pipe on the rack with the fork lift. So maybe @ a ton, including the rack. No problem at all for the body but the handling scores a perfect 10 on the pucker scale! Cheers!
I have Kargo Master PRO II roof rack on my 2000 E-150, they advertise the rack to be 1700 lb load capacity:
Heavy Duty Pro II Van Cargo Rack | Kargo Master
In the Installation Instructions they worn about not to exceed GVWR, locate load as low as possible and center it, danger of roll-over and such; but 1700# is impressive nevertheless. The rack itself is about 200 lb, and removal/ install is a chore.
sgtevmckay
03-17-2019 11:12 PM
kilshark
2014+ Transit
09-04-2015 01:57 PM
gorkah
12-13-2013 07:16 PM
EconolineFan
11-17-2013 12:48 PM
