Can't open rear hatch
Old 08-28-2016, 02:43 PM
Olafs 7.3 ex's Avatar
Olafs 7.3 ex
Olafs 7.3 ex is offline
Our 06 Explorer EB rear hatch stopped working yesterday, rear hatch will not open. The outside door handle moves freely but will not activate release mechanism. Hatch window is working fine. Any help would be greatly appreciated.
Old 08-28-2016, 03:57 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
There should be an emergency release on the inside. Probably covered by a small removable cover. Push press, pull or whatever to release it. Might be able to find the problem once the hatch is open
Old 08-28-2016, 08:32 PM
Olafs 7.3 ex
Thank you for the reply. No luck with finding a emergency release. However the rear hatch must have sensed that I have enlisted the aid of FTE. must have scared the heck out of it, and just like that it's working like nothing has ever happened. I will probably pull rear panel off and check things out when I have time.
Old 08-29-2016, 02:57 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
Yet another miraculous healing thanks to the fine folks here at FTE. Glad it's working again
Old 08-29-2016, 09:24 PM
shorod's Avatar
shorod
shorod is offline
Is there any chance you had the doors locked and that's why the hatch wouldn't open? Do you have the doors set to automatically unlock when the engine is shut off or did you maybe still have the vehicle running when you tried this?
-Rod
stu37d
05-05-2005 01:08 PM
The Undertaker
Aerostar
01-02-2005 06:57 PM
Angelita
08-19-2003 12:23 PM
Quick Reply: Can't open rear hatch
