Key on power for Dash Cam
I am looking to see where people powered their dash cams? I am looking for a key on power wire to tap into because the cam doesn't have a parking mode anyways. I already used the white/blue customer acess wire to install my pac module for the radio, so that is out. Ideas?
Okay, here is something I can answer. I am currently installing a front view, Rear view and trailer rear view camera. My Kenwood aftermarket radio has a front and rear camera input. I used a splitter on the rear camera input so I have two different video inputs. I am installing three rocker switches in my overhead center consul, First switch is going to power the rearview camera on the truck at any speed, Second switch is going to power a remote wireless transmitter that in installed in the rear of the bed. (Receiver is installed in the trailer 7' away). I am not using the reverse lights as a trigger as I want to be able to call up either of the rearview cameras at any time.
Front Camera is controlled by the media switch on the steering wheel.
I will start a new thread and keep everyone informed.
Trophy 23,
Isn't that white/blue Customer Access wire powered by a 15 amp fuse? (if I remember correctly - and that's a Big IF for me) - if so, I would think your pac module & back up camera wouldn't be near that amp draw. The only other thing I could think of would be adding a relay triggered by the Customer Access wire but you would still have to run a fused HOT wire from your battery to your relay - which I'm sure that's the part you're trying to avoid.
I feel your pain. I have an 06 and I personally don't feel that Customer Access wire is large enough to handle a 15 amp continuous draw. I was thinking of going the Bosch style 4 pin relay triggered by the Customer Access wire & bringing a 10 gauge fused hot in from my battery to a small terminal strip or separate fused box something like this for $12.00 https://www.amazon.com/gp/product/B0...A1EQP448COWZL4
just a thought.
just a thought.
Roger T. Pipe
12-30-2018 07:57 AM
90pioneer
6.7L Power Stroke Diesel
07-07-2015 07:53 PM
