fan clutch. left or right hand thread
Old 08-28-2016, 12:49 PM
dyoungen's Avatar
dyoungen
dyoungen is offline
I have a 1987 F250 with a N/A 6.9. The water pump is wobbling like it's about to throw the whole mess. Is the fan clutch a left or right hand thread? I think it's left hand but want to make sure.
Old 08-28-2016, 01:23 PM
Pkupman82's Avatar
Pkupman82
Pkupman82 is offline
Should be left hand on the 6.9/7.3 with V-belt system.
Old 08-28-2016, 02:04 PM
dyoungen's Avatar
dyoungen
dyoungen is offline
ok, yes I have the vbelt system. the smaller bolts are regular right hand bolts that hold the clutch to the pully, correct. Maybe i better back up and ask how do I get the clutch off the water pump. I have the big wrench set for removing the left hand clutch nut but do I also remove the 9/16 bolts from the clutch to the pulley?
Old 08-28-2016, 02:48 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
With the V belt system you need to rotate the big hex nut towards the driver's side to remove. The holding tool (really big wrench) engages the bolt heads to keep the water pump from moving.
The pulley and bolts stay in place until the fan is removed, then pull the bolts and the pulley will come off the water pump.
Old 08-28-2016, 02:53 PM
dyoungen's Avatar
dyoungen
dyoungen is offline
Thanks Ford Six. I just got the 4 smaller bolts out of the pulley. so I guess i put them back in and start over. I did this about10 years ago and totally forgot how to get the fan clutch off
Old 08-28-2016, 05:49 PM
The_Josh_Bear's Avatar
The_Josh_Bear
The_Josh_Bear is offline
Sounds like you got it figured out. But if you haven't yet:
A tip I figured out was to loosen those 4 smaller bolts about two turns each. At least with the kit from Oriellly's, the big wrench that goes over them can't get a good purchase with them snug to the clutch. Made a WORLD of difference the last time I did mine.
And don't forget to either torque the fan nut real good or use some blue lock-tite!
Old 08-28-2016, 07:25 PM
dyoungen's Avatar
dyoungen
dyoungen is offline
FINALLy got the nut off and the water pump off. I used the blue loktite when i replaced the water pump about 10 years ago. it definetly wasn't coming off
Groundpounder0331
08-19-2015 10:59 AM
toolmanx
12-27-2011 06:20 PM
topscrt
Modular V10 (6.8l)
07-22-2009 07:53 PM
jodum
04-11-2004 10:25 AM
jop1212
Aerostar
01-27-2003 02:15 PM
Quick Reply: fan clutch. left or right hand thread
