you might want to try this guy. Flashback F-100.com. looking at their web site it looks like they have some trucks that they sell parts off of. i have not used them so i cannot say if they are good or bad.
Guess I need to look at a 67 and a 68-72 side by side and see what's diff.
1967: You push the inside door handles forward to lock the doors. 1968/72's have door lock *****.
1967 only: Door shells, door lock remote controls, window regulators, window and door crank handles, vent frames and handles, door latches, door lock cylinder rods, arm rests, door trim panels.
1967/72 same: Weather strips, division bars, vent window and door glass, door lock cylinders, outside door handles, upper/lower door hinges.
What's different between the 67 regulator and 68-72 regulators? I have 67 doors on my 72 f250, and I replaced regulators with ones from a 72 f600 and they fit fine.
Might have something to do with the stem the window crank handle mounts to. 67's take a different window crank handle than the newer ones.
