1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
ABS not pulsating?
Old 08-28-2016, 12:01 AM
frdbronco8's Avatar
frdbronco8
frdbronco8 is offline
ABS not pulsating?
Test drove an 08 V10 today. Brakes seemed to work fine and didn't lock up but I felt no pulsating in the pedal and heard no chirping of the tires like most ABS systems do. Is this normal?
Anything special to look for in used late model V10s?
Thanks
Old 08-28-2016, 07:41 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Did you test it in a situation where it should have triggered the ABS, like on a gravel surface and then apply the brakes very firmly?
Does the ABS light self-check when the power is first turned on? If not, the system is probably broken and either the bulb is burned out or the PO removed it.
nashr1
1997 - 2003 F150
08-22-2004 12:08 AM
krewat
12-05-2003 01:38 PM
jetjock16
01-10-2003 07:50 AM
tetraruby
07-12-2002 06:44 PM
Quick Reply: ABS not pulsating?
