Why is my 239 Y-block dying?
#92
With Harrier's current gearing I can't see a point to a 4-bbl... 94's have their issues (mostly the PV) but they are decent for economy.
#94
It's all great info though. I'm tempted to get a 2110 carb, but since I won't be driving cross country (especially with my gearing) my 7RT is probably fine. I do wonder how it got on the truck though....
Shoot, I still need to order the power valve. Looks like I have a task for this evening. I also need to see if O'Reilly has a vacuum gauge as a loaner tool....or I should get one of those too.
I do find it interesting that my troubles seemed to be all carb related. I also didn't actually do to much to it....I still have lots of learning to do, but it's sure a joy driving the truck when I don't have to worry about it dying at stops.
#95
Joe, a vacuum gauge is relatively cheap and you will use it in the future. Believe me, it is a handy tool. I have one installed in Blue. There is nothing that will tell you more about how your old engine is running.
That jet that is stopped on your carburetor should be easy to clean. A few squirts from a can of carburetor cleaner should clear it. If not, a very soft small copper wire will.
Edit: Someone will be along with the correct carburetor for your truck. So far as "How that carb got on the truck"? When that truck was used daily it was common practice to install rebuilt carburetors on a vehicle, not always exactly identical to original.
#96
Now having said all that, I would probably only change from a "Towering Inferno" carb if I had one. (you do not!) Rebuilding that 7RT should be at least as "easy" as rebuilding any other simple carb.
I only changed mine to get a (new) 390cfm Holley 4v carb with a throttle position sensor!
It should work at least as good as that 2bbl in my picture!
I totally "get" staying with the 239, AND to "keep it stock"
Just rebuild your carb and don't forget to add some sort of fuel filter!
Cheers,
Rick
Coletrain816
08-10-2019 04:15 PM
RedTaurus94
18
06-18-2014 10:44 PM
Lifted79
21
02-20-2003 04:26 AM
