1996 F-150 Leaf Springs - Ford Truck Enthusiasts Forums
Old 01-08-2002, 08:19 AM
bktoney bktoney is offline
bktoney is starting off with a positive reputation.
The rear end of my '96 F150 4X4 appears to be sagging. It is a short wheel base and the rear is noticably lower than the front. Does anyone know of a reasonably inexpensive way to raise like an add-a-leaf (what manufacturer), or should I just replace it?
BT
Old 01-08-2002, 09:16 AM
GammaDriver's Avatar
GammaDriver GammaDriver is offline
GammaDriver is starting off with a positive reputation.
Sorry, I don't have any insight into your question - but I do have a question.
Was this a truck that has been continually loaded down over the years? I have a shortbed, standard-cab 1993 that has the opposite problem - my rear leaf springs keep the rear end up relatively high (to the point of making me want to lift the front end up to level the bench seat back out a little).
I'm wondering if heavy duty springs got put on mine, or if the truck was barely ever used to carry loads.
Thanks!
Old 01-08-2002, 09:38 AM
bjoern bjoern is offline
bjoern is starting off with a positive reputation.
Old 01-11-2002, 04:37 AM
madman666's Avatar
madman666 madman666 is offline
madman666 is starting off with a positive reputation.
If their sagging really bad, you might want to replace them, they could fail when you’re driving.
You could get add a leafs, go to:
http://www.jcwhitney.com/item.jhtml?ITEMID=10625&MEDIACODE=UT
Explorer pro comp also make an add-a-leaf.
Old 01-11-2002, 11:00 AM
KevinLaRue KevinLaRue is offline
KevinLaRue is starting off with a positive reputation.
Forget add-a-leaf. Go to your local spring shop & properly repair your spring set.
Change Rear Leaf Springs?? CaptFX4 2004 - 2008 F150 2 01-18-2013 06:57 PM
78 f150 leaf spring count clhart426 1973 - 1979 F-100 & Larger F-Series Trucks 9 09-17-2010 07:30 PM
Leaf Spring Conversion clhart426 1973 - 1979 F-100 & Larger F-Series Trucks 1 12-30-2009 12:41 PM
add a leafs Bigblack Ford 1987 - 1996 F150 & Larger F-Series Trucks 3 07-26-2009 02:16 PM
rear leaf springs mike_v2v98 1987 - 1996 F150 & Larger F-Series Trucks 8 12-01-2002 06:11 PM
Tags
150, 1996, bed, duty, f150, ford, google, heavy, leaf, rear, sets, short, spring, springs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
